toxicwaste29
So my starter went bad and I replaced it. I undid the positive battery cable since I didn't want to arc a wrench while undoing the starter cables. I put the new starter in and put the positive cables back on he terminal and they sparked which is normal for a battery; not a huge spark just a little one; the starter issue was fixed. After driving it down the road the engine light came on and now it has a p480 code which is for the cooling fan. Also recently my front turn signals have been working and then not working; the dash tells me this and also you can see they aren't working this randomly happens. It happened again on my way home; I pulled into the drive, shut off the jeep and turned it back on and now my turn signals are normal again. Im thinking it could be a bad ground but my cables are all tightened and it all started after replacing my starter. Does anyone have any ideas?
