Ok, so Ive posted in a few other threads , so I thought Id start my own.
For some reason I just cant grasp the whole pinion angle - caster relationship and I have read the various threads here and on other forums as well as watched videos etc. First time doing an axle swap and starting from scratch. My past 2 jeeps I got close on the measurements and then had it aligned then came back and made adjustments like everyone has recommended and all was well.
Buster3479 stated in this link "Rear driveshaft angle. I was able to set the rear axle pinion pointed directly at my xfer case so that the 1350 shaft I used has a 0 degree change at the pinion end. It's just under the maximum angle Dynatrac specified on the hang tag they provided."
So do I point the pinion at the transfer case as in straight line or point at transfer case with the pinion at 0 degrees on the flange.
In this picture my Rear upper is set to 17 3/4"( stock at 17 7/16 ) and Rear lower at 20" ( stock 19 3/4) - Bump stops are now centered.
When I have my angle finder at ride height (no coils) it shows 77 degrees at the pinion flange - What should it read ?
Can someone please advise on if this is right or what I need to do to get it right.. thanks in advance
