Jeep Bro 08
What should i do about this i got a 3.5 R.KRAWLER lift stock driveshafts
Sent from my SM-G900P using WAYALIFE mobile app
Clean off diff and recheck, but looks like pinion seal leak.
Upgrade driveshaft to one that has a double cardan ujoint design instead of the rzeppa style.
Ok thanks. What brand you recommend that wont break the bank?should i do rear driveshaft too?That is the boot that seals the grease in the rzeppa joint. It gets torn from the steep angle due to the lift kit. A ujoint driveshaft will not have that style of joint.
I like local. Thankscall Stan Hopkins Company 214-398-0636, they 're near I-20 off of Hawn(?) Freeway
I hear they do good work.
Nice thing about local, if you have issues it's easy to get it taken care of.
I have adjustable lower control arms .so can i just replace pinon seal & then adjust control armsYou'll need new front lower adjustable control arms to dial in angles.
Thank youBuy an analog angle finder. Set you caster angle at 4+. The driveline angle will be proper when you do this.
https://wayalife.com/showthread.php...nt-End-Alignment?p=42391&viewfull=1#post42391
EDIT:The info I posted is for setting caster and driveline angle. The info is not for replacing the pinion seal. You do not have to mess with arms to replace the pinion seal.
