Driver Mirror
Be careful, but you can remove the glass. There are three screws( if I remember right) inside you can tighten. If you choose to replace, I found some inexpensive ones.ImageUploadedByWAYALIFE1425702764.218516.jpg look on car parts.com. Like $35.00
Since its the class have you looked to see if its the actual adjuster shaken or if the glass glue is coming undone?
The glass vibrates at highway speeds. I will look to see if the the adjustment will tighten up if not I will look at replacing it.
R/
Will
