Cousin Clyde
I’m finally going to pull the trigger on the PSC JK BIG BORE XDR Box and and pump system.
Thing is, I have this GM 1T rod end on my drag link at the pitman arm and the diameter of the rod end is slightly larger than most.
The pitch is typical but the diameter is just too big. (Really setting myself up on this one)
I reamed my stock pitman arm a bit and it worked well for a couple years, but now has a little play in it.
I would rather not ream my new PSC pitman arm.
Can anyone recommend a good rod end to use with the PSC pitman arm that doesn’t require reaming?
Is the PSC pitman arm 0.749" diameter at the tapered hole?
Here is what I have.
