Double Cardan DS
Zeus
Hi Guys
Some advise please...
So I replaced my front stock drive shaft with a Spicer parts DS as the CV started spewing greese. (we cant get Adams or Tom Woods in South Africa)
Here is my question, someone told me I cannot travel highway and long distances with a double cardan DS up front he actually said he disconnected his for highway driving, is this true?
My Setup
2 Door JK Rubicon, 2.5 AEV with drop brackets and 35's 4.88 gears
Your advise will be appreciated.
Thanks
Definitely Not true.
If he disconnected for highway driving was it because of vibrations? His could be out of balance.
If you get vibrations, you’ll need a solution. Removing the drive shaft is one solution, albeit not a practical one. Adjusting the pinion angle is another. That usually requires adjustable control arms.
Hi Guys
My Setup
Thanks
First off, the grease that you saw is not a big deal. Most likely excess just getting flung off and nothing to worry about. Second, you can totally drive long distances with a double cardan drive shaft. Disconnecting it is just stupid.
Thanks Eddie
No mine is 100% no vibrations, I was just told you cannot drive with a double cardan for long distances on the higway
That all I wanted to make sure of as I never heard that before.
Thanks
For whatever it’s with, I think Spicer makes a quality drive shaft and better than some of the popular name brands out there.
