StrizzyChris
Total Parts list from Ace Hardware
2- 1.25" x 2" angled truss clips @ $0.79 each
2- 3/8" fender washers @ $0.25 each
1- 3/8" Hex bolt @ $0.45
1- 3/8" nut @ $0.12
2- 3/8" lock washers @ $0.20
1- bag of #24 1.25" bolts and nuts @ $1.18 (only used 2)
Total Cost = $4.23
First I measured and marked (2) 1.25"x2" angled truss clips for drilling and bending
Drilled a 3/8 hole in the clip for mounting a hex-bolt through
I used the preexisting frame hole to mount it. This is the hole just below the front body mount. On both sides I used a 3/8" fender washer and lock washer as well as the 3/8" bolt and nut
I then used a table vice to clamp and bend the second truss clip to clear the winch in the front, then to bend up and over the mount for the old swaybar guard/lower air dam mount. I bent this tightly as to "clamp down" and secure itself on install. I had to use a hammer to tap it down onto the frame bracket.
Once the two brackets were installed I mounted the Vacuum to the tabs using size #24 1.25" bolts and nuts. Trust me, you will want to do this before you install your winch. The tolerances are a complete PITA and you have to be a contortionist to place the nuts in the screws.
This is the front mount
The back mount
1- 3/8" nut @ $0.12
Total Cost = $4.23
The back mount
