Dana 60 SMF Upgrade worth it?
SAWTOOTH4X4
I can't decide if I should just bite the bullet and get the semi float D60 from Fusion with the electric locker for my 2020 Gladiator Rubicon. I broke the ring gear in my rear axle 5.13 gears, and now I don't know if I should trust it. I'm Running 37x13.50/17 cooper tires. I'm sure I broke it snow wheeling.
I don't want to buy new wheels, I have a set of trail gear beadlocks I am going to install on it someday when the cooper tires wear out.
I do not plan on doing anything else to the front axle except a truss and CV axles. Its held up fine for 100K miles.
I use the truck in Moab and for a lot of just exploring the back country. The load in the back can be heavy with my extra battery, refridgerator, bed slide, fridge slide and all the gear.
I have the parts to rebuild my rear axle, but just don't know if I want to spend $7k on a D60.
Definitely not worth it. Not to me anyway especially if you're just running 37's. Semi-float 60 is a big waste of money all in itself and all that you mentioned you would need to buy to make it work, really isn't something I would do.
As you've noted, you've made what you have now work for 100k miles and admit you probably broke your re-end snow wheeling. Just fix it and go easier on the skinny pedal next time.
sounds good. I'll just keep them the way they are.
I watching a video about the new full float rear axle on the 24+ wranglers. Maybe that would be a worthwhile upgrade. Or I just wait and get d60's front and rear when I put new wheels on my truck. LOL
another weird deal from Stellantass. Why is the full float rear not in the Gladiator already?
