LoPo
So today I was out mall crawling with my 3 month old and on my way home and noticed a drop in RPM's and a severe shake in the Jeep while waiting my turn to exit the parking lot. I rolled down my window and the sound was definitely not right. It was more of a clicking noise overplaying my regular dynomax rumble. Initially I thought exhaust leak. I decided to see what happened when gassed it in neutral, seemed alright and around 3k RPM it sounded normal. I pulled out of the parking lot onto the road and that's when the check engine light hit me and a loss of power kicking in at ~2,200 RPMs. When overdrive kicked in, the RPMs dropped to 1,500 and the severe shake came back. Like the shaking was close to the death wobble I had when my OEM rear trackbar mount break on me. I stopped at the next stop light and the check engine light disappeared but the low rough idle returned. Light changed, accelerated, lack of power. Hit 2,200 RPMs check engine light came back until the next light. I limped it to my local O'Reilys and used their trouble code scanner to read the code, even without the check engine light on. P0302. Cylinder 2 Misfire. They printed out a list of possible fixes(pictured below)... I was unable to look at the Jeep since getting home and plan to take a peek tomorrow in the daylight and warmer temps.
I'm wondering if anyone has experienced the cylinder misfire on a pre-2012/non-penstar engine and what their fix was? I'm worried I'm going to spend a lot of money chasing my tail on this. I can manage the easy things like checking/replacing the spark plugs and even possibly changing a coil pack if I can find a how to. But getting into the fuel lines that will require a trip to a certified mechanic. On that note, do those fuel cleaners you pour into your gas tank work worth a damn or would that be a waste of $$ and time?
Below is a print out O'Reily's gave me with potential fixes. Deep down I'm hoping the engine is toast and I will 'need' to get the LS swap.
