Currie LP 60 rear axle
Nick V
Greetings, is anyone running a Currie LP 60 rear axle in a JT with the RockKrawler pro x rear control arm setup, if so , what cradle / truss are you using for the upper control arms ? Thanks in advance.
Are you referring the the bridge for the rear upper control arms?? Rock Krawler includes it with the kit but sure it has to be modified a bit for the Currie 60. They also have a truss specific for a 60 sku: RK05996 but will still need some modifications for your control arm mounts as this one is set up for a 3 link.
Upvote 0
