A JK 2010
What should I do? I was thinking of sanding it to bare metal and welding it. I didn't find a crack on the back side. Don't know what needs to be done?
That was caused by your trackbar drop bracket you installed. I would remove it, weld it, and then install and axle side bracket to raise it and flip your drag link at the same time. The evo drag link flip kit will do that
I would do what Cozdude said as well. If you're dead set on keeping your current setup, I would weld the crack, then weld a 90 degree .250 L bracket over it and connect it to the frame above it.
