Cooper STT Pro
Probably not. BFG tends to make tires that are smaller than what is listed on the sidewall.
Eddie,
What would be the largest size tire I could run with no issues & the EVO 1.5” leveling kit?
Thx!
35s all day. Heap of people on here, including myself have run this setup with no problem. Only problems you’ll run into is just having to trim your fenders, and or adding an inch or 2 more of bump stop.
What size tire would be in between a 255/75R17 and a 35?
Thx!
A 255 is 32 inches high (off of the Jeep). A 315 is 34.5 inches ( off of the Jeep). A 285 is likely what you want, however, if you're going with the stt pros, they make a 295 that's slightly taller than a 285. I loved them when I had them. This thread may shed some light as well:
https://wayalife.com/showthread.php/36815-295-vs-315-70R17-Tires-on-2-Doors-No-Lift
And here's a picture of a 295/70R17 (left) vs a 315/70R17 (right). Obviously it's a little deceptive because the 295 has the weight of the Jeep on it vs the unloaded 315 on the right.
