Christarp
So, I have a rubicon express 3.5" superflex lift with 35's and I just can't for the life of me figure out why the ESP will kick on in turns. After everything i've done it's gotten "better" but it still kicks on prematurely for reasons unknown to me.
When I installed the lift I paid careful attention to how many threads I had showing on each side for the upper control arms (the lower control arms aren't adjustable), so the axle really should be straight, then I centered my steering wheel by feel, and it still kicked on, and I figured the last piece of the puzzle was tire size, so I got a procal and set my tire size, and low and behold it still kicks on prematurely (but as stated before, it's better than it was).
So after all of this I decided that it must be a steering wheel centering issue. So I got a laser pointer and a few straight edges and a marker to try and center it as best I could, this is basically the set up I used.
Then after I had all my measurements taken, I turned on the procal, set it to the steering wheel centering mode, and it turned up already centered. So I turned it off center and re-centered it (It was basically the exact same position on the draglink) until both turn signals illuminated as described in the directions.
The steering wheel is dead on straight, and I'm still having ESP kick on during long bends (eg on-ramps), but not short quick turns. I can fling it around a corner pretty quickly without the ESP kicking in, but as soon as I take a bend at a lazy speed it will just go full retard and kick on, despite not getting anywhere near the feeling of being in danger (such as more body roll than one would like).
At this point I almost just want an ESP kill switch, but I know that one day it could help in an emergency situation..
