The story.
I was driving home from work when i hear a hiss dont think much of so i continue to drive, the hiss gets louder and louder, then the bad stuff happens. the check engine comes on and i know that i have issues that are getting worse but have to get it of the highway because its a toll road. a mile from my exit it gets real bad and start to slow down even with the pedal pushed to the floor (i know bad idea right) then cel starts to flash, and engine starts to shake. get it off tow it home and start diagnosing problem has only one code for random multiple cylinder misfire. so start with the obvious and went to plugs and wires, no go. then to coil pack, no go. then to vacuum leak, no go. then compression tested and guess what cylinder one and three are bad not getting over 90 PSI (tested multiple time). so did a wet compression test with the same results. removed the heads and put some sovent in the runners and they leaked like no other. so i started tearing down, i thought originally that i would just get the head redone and put them back on but then i thought, its down this far so why not hone the cylinders and rering the bottom end while im at it, now i am just waiting to put it back in, will post more pics as i get closer.
