Broken Driveshaft Help!!
FastZach
So we went ran some of Willow Springs trail here in AZ today. Came out with some carnage. Broken front DS and a bent "unbendable" aluminum tie rod.
The DS broke at the T-case yoke. Not sure what brand it is but what do I need/buy to replace it??
That inner yoke needs to be replaced and so does the U joint. If you have a shop do it it'll be about $150 or so. Depending on how hard of a hit it took I would probably replace the other axle side u joint also.
How do you know that?
Thanks for the info
What about the t-case yoke, I think the screws broke off inside. How much are those??
Thanks for the info
The only bolt I see broken is on the inner yoke and that whole piece will be replace. If the other three bolts are broke in the tcase yoke you can use an extractor to get them out and just put new ones in.
