bobfriesenhahn
My 2019 2-door JL Wrangler Rubicon has a severely bowed left front spring. This is from a dealer-installed MOPAR 2" lift.
The lift was installed about a week after I bought the Jeep. In some (city driving) situations I heard an annoying rattle on the left front side. I brought the Jeep to the dealership which installed the lift (Rchardson Jeep) several times. The dealership seemed to have a policy that the Jeep must be parked for at least four work days before they would touch it. So the Jeep spent a couple of months in the lot. The situation was that they "could not reproduce" given that the nearest gravel or dirt road is 30 miles away.
A tech thought that the brand new sway bar end links might be to blame, and so the end links were replaced under warranty.
Then I brought the Jeep to a different (better) dealership and paid for a tech to look at it and make sure the torque is correct on suspension components. In this case they did not tell me that they "reproduced" the noise.
On this latest trip to Arizona, the rattle on a dirt road was the same as before and I took a look at the left front spring. The spring is bowed toward the sway bar end link, with a gap so small my pinky finger can't fit between the end link and the spring. The gap between the upper bump stop mount and the spring is also very small
Given the quantity of service, perhaps the spring was bowed since day one, or maybe it shifted.
My question about this issue is if this problem might be reasonably solved by repositioning the spring in the perch or if the spring needs to be replaced.
