advice WRT ring and pinion replacement.
machinegunmedic
I need some advice WRT ring and pinion replacement. I am looking at putting 4.56 into my ride. Is there one company that is better than the rest? (Yukon, Alloy etc). The dealership quoted me $1300 + tax for the install. Any other advice is appreciated.
Cheers,
2011 with 3.8l, auto, 33" (not moving up to 35")
All gear sets are made by the same company on Korea so brand doesn't matter. Just look for the cheapest install/gear set available and your good to go
Where'd you get that information from? That's good to know if it's true.
wayalife has posted about it multiple times and even provided pictures at one point as well. there is a little circle stamped with a "k" in the middle of it located on the ring gear.
I'll have to check that out. Thanks!
