ChicoJoshua
So I'm running out of ideas... figured I'd ask here before I go tearing the loom apart or hard wiring them... Anyways here's the deal; Both front and rear lockers wont engage via the switch in the cab and the light on the dash just flashes. Confirmed they are not engaging with all 4 in the air. Checked connections at the axels, fuses and relays. Also jumped the relay and confirmed both front and rear engage, and then show steady light on the dash. My next idea is some switch in the TC that tells the comp that it's actually in 4lo? But, when in 4lo the dash knows it and the revs jump so the comp must know it, right? Background info, '08 JKUR, replaced the TIPM about 3 months ago(I did check most things when I installed, but not lockers). Also, not sure if it helps but my e-sway bar disconnect must have been built on the right day and still works great. I do see low voltage codes to the lockers, but clearly that's due to them not engaging(right?). Anybody got an idea of where to go next? I'm half tempted to just bypass them to get the lockers in any TC position but I'd rather just get em working properly. Thanks in advance!
