Whats a good psi to air down to for 37x13.50 on a NON beadlock 17x9 rim?
Ive been using 15 psi
Thanks
15 psi is good for most wheeling. If needed, I might still go down as low as 10-12.
Wow, you like to start early
Thanks!
10-12 is ok even without beadlocks?
Thanks!
Remember that you'll likely end up lower than what you started when you are done wheeling. If I start at 15, I am usually around 10 at the end of the day. If I start at 12 or 10 I've ended up around 4 or 5.
This is without beadlocks and 37s.
FuriousDz said:Thanks for the info.
4 or 5I wouldnt think you can get that low safely without beadlocks
A good PSI for stock tires on my 2013 Sport?
Donny
Donny said:A good PSI for stock tires on my 2013 Sport?
Donny
