A few questions about my TJ
Tyman
My name is Tyler and im new to the forum and to the jeep community!
I recently purchased a 2006 jeep wrangler "x" it has 15000 miles. I recently purchased a 2.5 lift springs front and rear with rubicon express shocks on all 4 corners for now..I threw the lift on and on my way to get an alignment I noticed i had a bad case of death wobble, since then i have been trying to track down the problem. I have went thru the checklist and everything is fine. I purchased front offset alignment cams thinking it would fix the problem but it did not, it used to get the death wobble at any speed and now it only gets it at 45 mph plus, (I only have a 5 minute drive to work and speed limit is 25) other than that i dont drive it anywhere else. I bought adjustable lca from poly perfromance and will drive down there later this week and pick them up. my question is what is the desired pinion angle to accomadate a 2.5 inch lift (it came to about 3inches of lift after all) any help would be greatly appreciated!
With adjusting the front, you need to account for the caster. I'm currently at 5.5* with 4" coils, but at 2.5" of lift, it should be close to stock and shouldn't require adjustments, unless your arms are shot and need replacing. In terms of death wobble though, have you done the dry steer test?
Yes i did do the dry steer test and everything checked out 100% this is the last thing i can think of other than an adjustable track bar. im hoping they will be into poly tomorrow so we will see!
