aermid
I really don’t want to melt anything, and please excuse my simple diagram/possibly bad questions. I’ve wired some simple stuff to my sPOD that goes directly to the battery, but I’ve never ran anything to the fuse box.
I’ve added heated seats, that have a 6.5amp draw each. They came with their own 10amp fuse, which I’ve removed so I could run the wires through the firewall. Originally my plan was to now join those two wires together, and then have a 3rd single line run to the M8 “FT Heated Seats” 20amp fuse slot in the fuse box.
The manufacturer appears to be using 16 gauge wire on the other side of the 10 amp fuse tap they supplied. I was going to run 14 gauge from the joined section to the fuse box and use a fuse tap for the 20A slot.
I have a sport, and I do not have factory heated seats installed, but there’s an existing 20A in the fuse for the M8 “FT Heated Seats” slot that the factory has there.
So here are my questions:
1. Should I use 12 gauge between the fuse tap and joined wires instead?
2. Should I put the 10A fuse they provided back into the circuit, and join them closer to the fuse box as 1 line? Is that overkill?
3. Can the fuse tap have a 20A on the top and bottom? I’ve read some places that says use a lower fuse than the original. My thoughts here are, isn’t it a different circuit and should be okay running the same?
Here is what I’m talking about drawn up with the provided fuse tap
Thanks very much
Thanks very much
