JEEPnGEO
I did the bolt swap and was totally shocked to see the factory bolts VS the new bolts. I love how the new ones fit and the way they perform. After I installed them I had a very tame drive to the shop where I get my alignments done.
I also did something different. I took the captured nut and removed it from the key and placed the new nut in there and welded it in place. I had to take a grinder to the nut to make it fit. It worked like a charm. Here are some pics.
Without the edges. I used a chisel
Ground the bolt with a bench grinder
Welded it to match the original. I did both sides.
Finished product
Can't see the head but you can see the captured bolt right there kind of laying down. I want to get a steering stabilizer with a smaller diameter. I have no clue what is on here and how good it is. Looks like it is leaking a little too.
I replaced both lower and upper bolts.
I noticed a change in the handling on my way to the alignment shop. I almost didn't get one.
I did use lock washers and Grade 8 hardware.
Finished product
