Five-N9ne
Might as well put a thread here to keep everything together.
Basics:
1998 5.9 LX Grand Cherokee, Platinum Silver Metallic
196xxx on shell
46RE trans
LP30/44A axles with 3.73 and Posi
249
Bought the ZJ I’ve been looking for since high school in September for 1300, trans hesitated like it had a bad governor pressure solenoid (as most electric Mopar transmissions are wont to do) and had a bad plenum plate and what seemed like ringland damage to the motor. $1300 for the cleanest New England unibody I’ve ever seen, clean Carfax and a mint interior with all the Niner goodies still in place... the Holy Grail of ZJ’s, an unmolested 5.9.
Day it came home:
I’d been looking for a shell to move my drivetrain, Clayton arms and fiberglass goodies to from my 96 5.2. I’d been building a .040-over 5.9 for that one, and this was a perfect home for it.
Motor pics:
Specs on the motor are:
.040-over bore to 367cid or 6.0L
Mopar Performance double roller timing set
MP rotating assembly
Keith Black .040 pistons
Mahle bearings
MP lifters
MP HV oil pump
MP valve covers/breathers
Edelbrock hardened pushrods
Ford 1.7:1 roller rockers
MP valve springs
Hughes plenum plate
FlowKooler water pump
Ford Racing 30# injectors
PSC power steering pump
MP R/T heads .010 decked
Valve cover stud conversion
ARP head studs and crank studs
Hughes crank girdle
MP ECM
Fastman 2bbl throttle body
I’m sure I’m forgetting a few things. The trans is getting Kevlar bands, new OEM solenoids, a Fairbanks shift kit and a deep dish pan.
The motor is in the process of getting pulled out of the Niner right now, trans/t-case still attached, so I can do the trans work on the bench and swap to a 242 transfer case as well to get rid of the stupid AWD-only case Chrysler stuck behind all the V8 Grand Cherokees.
Non-drivetrain stuff that’s going on:
Painless Trail Rocker
Hella 4000 on bumper
Hella 500s on roof
Lund visor
Hannemann Fiberglass front fenders
Kevin’s Offroad lower radiator support
Full Clayton subframe
Fox 2.0’s
4.10s front and rear
Addco sway bar with disconnects
Clayton triangulated 4-link rear, radius arm front
WJ big-brake/steering swap w/solid cromoly drag link/tie rod
U-joint front shaft swap
Novak cable linkage for the T-case
Iron Man 4x4 poly motor and trans mounts
OBA
Detours Knucklebone
33x12.50 Toyo MT on factory Ravines
Probably more I’m forgetting but I have such a pile of parts from the old ZJ I’ve lost track. Updates to ensue when I’ve done more than drain fluids and disconnect sensors and wires from the motor.
Basics:
196xxx on shell
46RE trans
249
Day it came home:
Motor pics:
Mahle bearings
MP lifters
MP HV oil pump
MP valve springs
Hughes plenum plate
Hughes crank girdle
MP ECM
Hella 500s on roof
Lund visor
Fox 2.0’s
OBA
Detours Knucklebone
