4WD Indicator dash light
TXJeeper24
Has anyone dealt with the 4WD indicator light not coming on thus rendering the hill descent button useless. If it’s a fuse, which one is it?
The fuse legend is on the underside of the fuse box lid. Right under the hood right behind your battery.
The light is just an indicator. It seems most likely that the issue is with the switch/sensor which detects the transfer case position. If you have a warranty then the dealer should address this for you.
