RebelconJk
Hi there, just wondering if anyone is running 40s on their Dana 44s? I'm currently running 37x12.50 17s on my Rubicon. I have the teraflex 6in long arm kit on there. Just wondering if the 44s can take that big of a tire?
I tried it once. Lasted about 2 months and only 9 runs. As mentioned, you can build up your housing all you want but in the end, the small internal components will be what ultimately breaks. I personally wouldn't recommend it.
9 runs? Hell at the rate I'm going that's like 2 years! Gonna order me some 40s today! :rock:
But you can run 37s on Dana 44s with no issues?
Don't know if I said that. What I will say is that everyone has their own idea of what "wheeling hard" and how "often" is often. For me, I've had my fair share of problems running 37's on factory Dana 44's over the last 7+ years but, that's just me. I'm sure you can find plenty of guys who'll swear they run 40's on a Dana 30 and wheel their Jeep hard all the time and how you just need to be easy on the skinny pedal and really, maybe they can and maybe they do. Again, everyone has their own idea of what "wheeling hard" and how "often" is often.
I would put the following axle required or modifications for tire size as:
33" - max for stock no change axles and you should be completely safe.
35" - stock D44 with Chromoly axle shafts, Inner C gussets, and maybe inner sleeves or truss on front and re-gearing to get back to stock or better ratio.
37" - axle swap to PR44 or similar with better than stock ratio, plus steering sector shaft and tie rod upgrades.
40" - D60/D80/14B with hydraulic steering assist.
Or throw on a set of Rockwells and run whatever you want.![]()
Thank you! Is there a difference between Dana 44 and PR44?
Partially agree. ProRock 44 up front with no more than 5.13 gear ratio. Any higher and your pinion will be too small and WILL be a weak link. Chromoly shafts would be a must for me. Sector shaft brace is a waste of money. A ram assist would be very beneficial. HD tie-rod would be beneficial on ALL setups. I personally would recommend a Trail 60 for the rear especially if you live out west. East coast guys don't need to worry about this as much.
Yes. The factory Dana 44 is in reality, a Dana 30 with a Dana 44 differential. A ProRock 44 is made by Dynatrac and is BETTER than a true 44 in that it has bigger tubes, thicker tubes, massive end forgings, beefy brackets, can be had with built in 6° caster and has a proprietary differential design that offers the most ground clearance, bar none. They aren't cheap but you get what you pay for.
Yes centimeters. (That's French) :icon_crazy::icon_crazy:
I would skip the sleeves and would NOT run a truss I also wouldn't run with a truss, but I also don't like those skinny axle tubes up front and the EVO Magnum 44 sleeves give me a little peace of mind.
with no more than 5.13 gear ratio. Yes should have said this also.
Sector shaft brace is a waste of money I agree to disagree, but that is why we all have minds and can put these options on the table.
