RJV
Installed the Dynatrac 2" Endurosport lift this weekend. Quadratec showed a 5-6 week back order and Northridge showed it as discontinued, so I ordered it and it showed up 3 days later, so that was awesome. Really wanted to get this lift - mostly from seeing the review Eddy did of it a few years back. Install went smooth (had the Wayalife video up while I installed it lol) loosened all the control arms front and rear and retorqued on the ground. Only issue was that the bolts for the new rear sway bar end links/bolts were bigger than factory, so had to drill out the factory rear sway bar a little bit. Wasn't planning on the lift coming till April/May, so I didn't order longer front LCAs or new track bars, but at this point I'm not sure I will. Rides so much nicer than stock. Flexes good with the rubicon sway bar disco too. Put about 80 miles on it. Forgot to measure before, but feels probably 2.5-3" higher than stock, I must have been sagged out before. The tires don't look as small as I expected, but will upsize when these wear down!
