Speedy_RCW
Changing my plans so these are going up for sale. Local pickup only.
14 Bolt out of a 2005 Chevy 2500HD. Axle is built to bolt into a JK. Brackets are tacked in place and need to be final welded after mock-up in the vehicle. Truss is fully welded out as there is no suspension mounting point integral to it. Built with 8 degrees pinion angle ideal for around 4” lift. Here are all the details $3200
Artec 14 bolt swap kit
Ballistic Fab 14 bolt shave
ARB Locker
5:38 Yukon gears
Hubs machined and 52 tooth tone rings pressed on to match Jk
Modified to accept wheel speed sensors
All new bearings and seals
Brand new e-brake pads and linkage
Artec pinion guard included
Wheel studs swapped to 9/16-18
1350 Yoke
I might be missing some things but please ask if you have any questions. Most of the build of this is on my build thread.
ARB Locker
5:38 Yukon gears
1350 Yoke
