Close
Results 1 to 4 of 4
  1. #1
    Fresh Catch
    Apr 2017
    Arizona
    29
    Body rake and leveling question
    I measured the wheel well front and back. The back is only 1/8th inch higher than the front. I was considering the 1 inch lift kit but now concerned that the front will end up an inch higher than the rear. I have a new Rubicon 18/58 springs. Is the raked front not seen on all JKs?
    2017 JKUR
  2. #2
    Feb 2013
    Wahiawa, HI
    4,505
    That I'm aware of, rake is present on all JKs. So many factors can play into your measurements. As an example, most, if not all JKs lean depending on how much fuel is in them. Depending on what side you measure from and how much it's leaning at the time, you could get a different measurement. I honestly wouldn't overthink it. If you want a leveling kit, go for it. The leveling kit will remove rake and give you a slightly taller and more aggressive look.
    Here is my current rig with stock wheels and tires, and the Teraflex leveling kit. Hope this helps some!
    BOHICA / 2016 Mojave Sand JKU
    BOHICA Build Thread
    CRYSTAL Build Thread
  3. #3
    Oct 2011
    Carson City, NV
    39,862
    Quote Originally Posted by Mark85383 View Post
    2017 JKUR
    ALL vehicles have a rake and in my opinion, a leveling kit WILL make a JK look ass low. Of course, that's just my opinion.
  4. #4
    Been Around the Block gheller's Avatar
    Jul 2016
    New York
    342
    I agree, I think there is rake on all JKs but perhaps some more extreme than others depending on the springs.
    I have a 2017 (17/59 springs) and there was what I considered to be a slight take from factory. I installed a 3/4" leveling puck and that leveled it fine (to the eye anyway). I since installed an AEV 2" spacer lift which applies a 3/4" level overall and it measured level.
    If your seeing that your rake is mild a 1" level puck might be too much. Go with a 3/4" puck if that's all you want to do.
    Sent from Earth to Space and back...can ya give it a second!? WAYALIFE mobile app
