Looks sharp.Bumper & winch
Great bumper… had it for almost four years and it held up great!Bumper & winch
Look at Synergy’s HD ball joints, I think they are very stout.New bushings in my track bar and upgraded the Synergy sector shaft brace with a bearing type support instead of the bronze bushed one…
Then discovered this
I did look at those but ended up ordering Spicer HD jointsLook at Synergy’s HD ball joints, I think they are very stout.
Why did you get rid of it?Great bumper… had it for almost four years and it held up great!
only 4 out of 6 bolts for the winch? or the bumper holding the winch?Why did you get rid of it?
The only think I didnt like was the skid plates. I got it installed before the bumper, then had to take it off to bolt down the winch. But I could only get 4 of the 6 bolts installed. The lower bolt and only 1 of the 2 upper bolts on each side.
Skid plateonly 4 out of 6 bolts for the winch? or the bumper holding the winch?
I switched over to EVO gear, otherwise I’d still be running it.Why did you get rid of it?
That is really going to light up night for sure. Looks really sharp.My Gladiator received a new KC Gravity light bar and I finally figured out how to make the Rugged Ridge Snorkel play along with it too.
Congrats! Regarding the valve stems… You’re going to be fine with the cheapies. They are 100% out of the way with those wheels and millions of those stems are on the road and in junkyards still holding on. Now, if you’re looking for easy and fast air-down valve stems then yeah, may want to hold off till you get some new ones.Mounted my first Beadlock ever. Feel like i might have gone too cheap on valve stems. Feel like it went in too easy but they do seem to be holding air. Are slime valve stems any good? May go get them for the rest of the wheels…
Congrats. 40s too. Jealous.Mounted my first Beadlock ever. Feel like i might have gone too cheap on valve stems. Feel like it went in too easy but they do seem to be holding air. Are slime valve stems any good? May go get them for the rest of the wheels…
I’m with Mike. They’ll hold up fine. It is kinda surprising how you pull on them with that tool and they just pop in. I’ve dug into them pretty bad with tree branches and they've never leaked on me. Just make sure the round part is hard up to the inside of the wheel. As long as they are seated, you’ll be good.Congrats! Regarding the valve stems… You’re going to be fine with the cheapies. They are 100% out of the way with those wheels and millions of those stems are on the road and in junkyards still holding on. Now, if you’re looking for easy and fast air-down valve stems then yeah, may want to hold off till you get some new ones.
Its a lot of work but worth it for the garage beers and music.Mounted my first Beadlock ever. Feel like i might have gone too cheap on valve stems. Feel like it went in too easy but they do seem to be holding air. Are slime valve stems any good? May go get them for the rest of the wheels…
