sounds like a load of weight to be mounted to molle panels but i could very well be wrong. Is removing one of your seats to put goosegear out of the question for you?
The slide/mount would still rest on the bed, just secured to the molle to prevent it from sliding or moving around.
Cab is already spoken for.👍
I finally got my winch and bumper installed. It took Evo a day to ship the bumper, it took FedEx a week to get it all to me. The hoop went from California to Arizona, via Maryland.
Looks great! I kinda miss not having the hoop on my rig now LOL
I changed my 2023 Gladiator grill out to a 2024 grill and changed my old bumper to a Evo 1/4 pounder. Looks better. NOW- I'm trying to figure out what bracket I can use to re-mount the Fox shock reservoirs? Is there a specific mount that works or do I need to find someone to fabricate a bracket?
FYI- the reservoirs are "temporarily' mounted until I figure out the solution. Using my other vehicle until I get them mounted safely.
I personally have not seen any aftermarket brackets for the factory Mojave Fox reservoirs when using something like a Quarter Pounder bumper. Making something to make them work shouldn't be too difficult though.
ok- thanks for the reply. I watched your video on the KC Highlights Flex Era 4's you put on one of your trucks........great video, so I ordered them today!
Chirp Programming Baofeng UV-5 hand-held radios for GMRS NOAA and Eddie's special sauce with Linux
A while ago I purchased a couple of Baofeng UV-5R +plus (redundant, but that's the model moniker) which came unlocked for programming from the distributor. This is a dual-band (amateur and FRS/GMRS) unit that can be programmed by hand. Since I'm 75 years old, I don't have the time left to fat finger 60+ frequencies on the Baofeng keypad, so I decided to use my Ubuntu (Debian) laptop with the open-source (free) Chirp software and a $16 programming cable. Most folks use 64 bit WinDo$ computers to run Chirp, but since I used to believe Bill Gates was the Anti-Christ, I don't have access to any Micro$oft compatible hardware made in this century.
After downloading the Chirp software, installation on Debian was an almost trivial three-command line process and one to launch the Chirp software. I use Red Hat/Centos Linux at work, but the process is very similar as long as Python 3 is already installed.
sudo apt install python3-wxgtk4.0 pipx (Debian)
sudo dnf install python3-wxpython4 pipx (RH/Centos)
meljr@meljr-XPS-13-9360: sudo apt install python3-wxgtk4.0 pipx
meljr@meljr-XPS-13-9360: sudo find / -name chirp-*.whl -print
meljr@meljr-XPS-13-9360: sudo pipx install --system-site-packages ./chirp-20250221-py3-none-any.whl
meljr@meljr-XPS-13-9360: sudo /root/.local/bin/chirp
Chirp automagically recognized the radio and how it is attached to my laptop, so from that point, the programming was just like filling out and saving a spreadsheet to a file before downloading to the radio; almost trivial. Now in conjunction with my Cell, SSB/CB and the JT's SOS feature, I'm ready to drive back to Nevada next weekend and more off-road adventure.
