Replacement key
jamesrw30
Is the dealership the only place to get another key with fob? My jk only came with one key and I really would like a second to keep at the house in case my wife needs/wants to drive it. I'm scared to thing what one will cost.
Colorado4x4
You can program a new key yourself. You will have to look online because I can’t remember how the hell I did mine. It is one of those weird sequences where you put the main key in the ignition, lock the doors, unlock the doors, touch your nose, honk the horn 17 times and then drink a beer. I ended up getting a standard key (not the push button/remote start key) as another backup key.
jamesrw30
I'll dig into that. If it involves drinking a beer I think I can get it done. Where did you find an unprogrammed key? Just get a blank cut from anywhere that sells them?
Hilop
True value or OEM, I’ve had locksmith make a key and it stop working 3 months later so I made him come back for free. I have a True Value key made and it’s good quality and I’m on 2 years no problem.
jamesrw30
Found this one. So take this to ace or some place and have it cut.
X AUTOHAUX Keyless Entry Remote Car Key Fob 315Mhz for Jeep Wrangler 2009-2018 https://a.co/d/ff1FuCD
From what I'm seeing on procedures for programming online everything says you have to have 2 working keys, if you only have one it takes a key programming machine. Now my first thought is just use the same key twice and then do the process for the replacement. Will the jeep know I'm trying to do this and go nuts, or the process just not work all together? Also, there's no step for the beer. I'm bothered by that but will just insert that step as necessary.
jeeeep
I'd check ACE 1st, the ACE near me has the keys and was able to program mine.
no charge if it didn't work but it's been working great for over 2 years now
jamesrw30
Very interesting. I called local dealer to ask about programming a key I provided and it was $100. I'll definitely call ace and ask them.
kevman65
Not all Ace's do it, you may have to call around. The one closest to me doesn't, but the next closest is in a hoity toity neighborhood and they do.
jamesrw30
Talked to my local ace. A cut and program was something like $180. I still have to bring the blank. Trying to find out what the local dealership charges to cut and program. I know they charge $100 to program.
jamesrw30
That's what I've read. I thought just trying the same key twice but don't want the jeep to freak out and think something was going on and shut down.
