Cousin Clyde
Last weekend while changing transfer case fluid in my 2016 JKUR, I made a wrong move and the plastic tip slipped off of the end of the tube of the cheap fluid pump that I was using and it fell into the t case.
I drained it, fished around in there, used compressed air in the fill plug and a shop vac in the drain plug. Nothing. Can’t get it.
Drove it, drained and refilled the fluid. Looks clean.
Going into a shop tomorrow for a regear and the guy says he’ll pull the entire t case and split it open on the bench and get it out / clean up whatever’s left. I feel like I can break the case open without taking the t case completely off though…
What would you do?
What would you do?
