aermotor
Looks like the quote from dynatrac says they are 30 spline inner and 32 spline outer 4340 cromo shafts.
Is there a 35 spline shaft in the front I'm missing? Northridge has an option for a 35 spline ARB when you build it on their site (no clue if that's right or not though)
You can run 35 spline but if I recall, only with the ARB and RCV shafts.
You can run 35 spline in the front with the G2 Gold shafts and ARB locker. At least I know you can with a Rubicon setup PR44.
If I was spending all that money anyway, I would do the 35 spline as the G2 are only slightly more than the Dynatrac I believe.
The rear 35 spline is the 147 non rubi and 157 for rubi.
Are you sure on that? I've done a lot of research and there was another guy who did it who said it was 147. Also there is a tech bulletin posted saying the 157 is not approved.
