Jk6 hellcat
Brute
out in its natural habitat! Your rig is really starting to look good.
is it safe to assume since it out on the dirt a bit that your engine is broken in? cant wait to see some more videos of this thing but in action!
Got enough miles on it to change the gear & motor oil...just need to do a slight adjustment on the tcase linkage...4lo rear axle was hard to get into...everything else worked great
SPOOOBY
Were you rolling while trying to engage,with syncros it helps under 3 mph
If you're not living your dead already!
Brute
Yup...4hi was no problem, 4lo rear axle was tough...I did get it in, but I had to roll quite awhile all below 3 mph
SPOOOBY
Maybe it just needs to break in a bit ,one could hope. Hope it not internal. Crazyeyes
I hope you don't take this the wrong way but what in the hell is up with the front mud flaps?? Is that required in your neck of the woods or are you just wanting to protect the side of your rig?
