Tackerdown
Banned
![_1261651202.jpg](http://www.mountainoffroad.com/prod_img/_1261651202.jpg)
Is this style skid plate going to cause any problems down the rode. My reason for asking is that the front bolts to the engine mount bolts rather than with the oil pan bolts. To me I would think there is a possibility that it could damage the mount bolts or loosen them. I'm looking for pros and cons.![]()
that loooks like the m.o.r.e. offroad version. i looked at that one but ended up with the protek for the cross member coverage.
i like my evo setup for a few reasons
its a 3 piece setup. the oil pan trans and crossmember all have separate skids. i beat my cross member pretty hard. i dont want all that shock going to my motor mounts.
i like how the transmission and oil pan are higher. i havent hit them and hopefully wont but if i do its protected. honestly id probably screw up pretty good to hit the oil pan.:twocents:
True part of the trans. has a bar across it just not the front few inches.I got my oil first since there is not one on there stock or at least I didn't. Everything else at least has "some" protection. Then you can add from there.
andrew -
I run rock hard 4x4 full skid plate system and have come straight down on pointed boulders and just got a scuff on the plate lol
Ok after a little more thinking maybe I'll get the EVO, just in stages The price really isn't that different just to cover the oil pan and transmission pan. Would you get the oil or the trans. first?
