Nice write up sir, do you think it would be manageable to install this on a two door?
Ridiculously thorough video! great work
it is pretty quiet, I like my VT muffler but I'd like something to tuck in better.
Those Nitto's are loud!
That's exactly what I'm looking for. Hopefully Matt can hook me up with something that will fit my rig. Still sounds agressive but not obnoxious. I need the ground clearance more than anything.
After EJS let's catch up and crawl around under your rig.
That sounds really good. Nice and quiet. To me it sounds like you hear the actual sound of the engine more than you do the exhaust.
I can't hear it. :thinking:
I agree!! Well done.
I noticed the hum too of the tires.
This will NOT work on a 2 door, just not enough space pre-axle.
Also the hangers on a 3.8 are in a different location too!!!
Okay, here it is! We just posted up a short video that'll help illustrate what the Dynomax QuietCrawler Performance Exhaust System sounds like both inside and out of the Jeep and under different conditions. Please take note that we are running BIG 40x15.50 Nitto Mud Grapplers and the humming sound you hear is coming from them.
Gave you a like & comment on your Facebook post, but figured I'd at least thank you for the video here. I was thinking maybe i'd hear the exhaust more since i'm running quieter trail grapplers, but i'm also only turning 35s- so probably will never work the motor that hard, so would probably even out
Great write up. And timely as I'm developing an exhaust leak in the stock muffler so will be replacing soon. This was obviously your solution for the drone on the 3.6 and short dump due to EVO leveler set-up, which variation would you you suggest for the 3.8. I have actually relocated my EVAP back above the rear axle so plenty of space where it used to be and can go short dump or back past the rear axle which might be my preference. Thoughts Eddie/DynoMax?
Edit: Oh, and considering CA Smog compliance ugh).
