Name That JEEP Part
Were you able to clean it out and get it to work again? How much do you charge to help take a look at mine. [emoji6] Wondering if this is my issue?
Cleaned and greased and so far, knock on wood, it's working. What is happening with yours?
Lol. I'll help you do yours if you tell me where these pop rivets go on your Jeep.
Hint: Every JK has 2 of them.
Fender flair. Hidden to connect to front support I believe???
Thought it was electrical. Dating back to rubicon. Stopped working after going through stings.
Worked on it a while back. When opened the connection it had water and crud inside. Cleaned the connection, dried it out. Re-secured the gasket. The next Time I used it, the light stayed solid for a bit, went back to default as connected and flashing light again.
Time for a no-limits!!!
Mine was flashing constantly. I thought it was an actuator problem so I pulled it off and then realized it was something else when it still would not reconnect.
Hold the plastic piece on the front door/windshield frame???
Dang! We have a winner. The rivets help secure the windshield header weather strip ends to the windshield frame. Note: These rivets do not come with the replacement weather strip. Ask me how I know. Lol Good job JAGS.
