toxicwaste29
Ive been having the issue that when I hit a bump the jeep wants to veer off the road. I have the rk 2.5" kit with 1" spacers on top of that. I have adjustable mc upper arms in the front and stock front lowers. I knew the issue was with caster however after installing the Rancho geo correction brackets I still have the issue however not as often. I have had my ball joints replaced since they went bad on me with adjustable moog since they have a lifetime warranty, I have new tie rod and drag link ends, and also Im still running the stock tires which has been replaced in the last 3k miles. Does anyone have knowledge what my issue could be? Not enough caster (set the brackets for 2.5-3.5" lift), bad wheel bearing, something with the ball joints and chamber?
Thanks,
Justin
Thanks,
Justin
