Sway bar angle and ride quality?
You're probably not used to progressive springs. I would still get longer links.
No. Your sway bar angle will NOT effect your ride quality in terms of "stiffness" or make it feel "harsh" when hitting bumps. Assuming your tires are inflated to a reasonable psi, a majority of ride quality is determined by your coils.
post a pic of your sway bar,.
all a sway bar does is control body roll when cornering. As mentioned, they have nothing to do with ride stiffness.
Now if you're feeling a bit too much side to side motion when cornering then yes, an incorrect aligned sway bar will make the front to rear body roll behave differently.
The sway bars should be about parallel with the frame, just slightly down angled
as mentioned a few times....the harshness you are feeling, based on how you've described it, is probably related to coil stiffness. EVERYTHING I am about to type is related to your last sentence saying that you are trying to learn about suspensions, and is my feeble attempt to answer your questions
Slight changes in handling, however, can be attributed to you lifting the Jeep which in turn changes the geometry of all of your steering and suspension components. Depending on how high you lift your Jeep, there will be different routes that you can go to correct these changes and return your handling to a closer to stock feel. Examples of this would be adjustable control arms, drag link flip, axle side raised track bar bracket
What about the rear feeling different from the front?
I feel like the rear just goes over things weird. I am not sure if this is just a lifted characteristic of my jeep that I need to get used to or what.
When you buy a kit, you are truly at the mercy of the manufacturers choice in coil spring rates. This goes for EVERY kit company out there. If you run a crazy heavy Jeep with huge aftermarket rear bumper, carrier, jerry cans full of liquid, heavy spare ire and rim, roof rack and a ton of gear in the back, etc...then a soft coil will probably not be best for your daily or regular uses. The coils that you have sound like they are a heavy spring rate which is causing the(what I will assume to be a) lighter rear of your jeep to ride harsher than your heavier front where the engine rests. The only way to make your Jeep handle "like stock", after lifting and adding heavy aftermarket mods, would be to get a custom coil rate that completely fits your new lift and Jeep weight.........Long story short, you'll have to learn to deal with the new feel OR buy a softer spring rate to make your jeep ride more smoothly!
Can these weird feeling results come from the stock rear control arms
no. Having stock control arms will keep the ride "harshness" the same as stock. Not having the correct control arm lengths CAN cause drive line vibrations and/or poor handling at higher speeds and/or flighty feeling of the steering wheel .
or can the sway bar links being short cause a weird sensation in the rear while turning?
no. the only thing that effects your "feel" while going around turns at higher speeds is the sway bar itself. If you want your vehicle to ride smooth while going down the road, then you want a softer sway bar. If you want it to corner like a corvette, then you'll want a more firm sway bar. That being said, I have NEVER seen someone buy a heavier or more thin swaybar in a Jeep and usually only is done on larger and heavier vehicles like RV's or trucks used to tow.
Should I loosen axle side of control arms in the rear with the weight of the vehicle and re-tighten just to be sure they are sitting right? Thanks
This has nothing to do with what you are feeling BUT...Any time you lift a Jeep, you should have it on the ground and at ride eight before you tighten your control arm and track bar bolts. This will assure that there's no binding or stress on the bushings once the Jeep is on the ground.
Another question about the sway bars. I thought they would give harsh ride when hitting bumps that don't cause suspension to move at same time right to left. So if I hit a hard bump on one side it would be more harsh relative to sway bar stiffness. The example I always heard was hitting a speed bump would not but a pot hole would. Just trying to learn some things about jeep suspension. Thanks
This is not true. You are driving a sold axle vehicle. Any time you hit a bump going down the road, you will have shifting of the complete axle from right to left(or vice versa) depending on the severity of the bump or pot hole. upwards compression of the entire axle(like going over a speed bump) will shift the entire axle to the passenger side of the Jeep. A hole causing the entire axle to drop will cause the axle to shift to the drivers side of the Jeep. None of this has anything to do with your swaybar links OR coils. In this particular situation your coils will only change the harshness or severity that these changes occur.
I just wanted to clear up that I am not talking about changing the sway bar itself. I am talking about the angle at which it sits because of short links. The angle of sway bar typically has an affect on how it performs because the leverage is different at more severe angles. I know things about suspension I am just curious what people have experienced with there jeeps and ride quality (mainly how the rear acts during turning and over uneven roads). Regardless of solid axle or not a sway bar does in fact add stiffness to opposing sides. A sway bar essentially uses spring rate from which ever side is unloaded/ less loaded to increase the spring rate on loaded side resulting in reduced body roll. I will be ordering longer links and follow up on ride quality after I install. I do agree that the springs themselves are rather harsh likely because I do not have the extra weight of aftermarket bumpers yet. What are people experiencing with fox performance 2.0 shocks? It's a rainy day here but I will post a pick of rear sway bar angle soon. What are some differences you guys have noticed from stock suspension to lifted as far as handling goes? Thank you for the responses.
If you know it all why come here and ask? We give you an answer and you tell us we are wrong. Why ask?
I have Synergy coils and Fox shocks and couldn't be happier with the ride (loaded or empty), but then I have some heavy accessories on mine.
I agree with OJK, in that short links on your swaybar won't effect your ride. The only time they will effect it is if they are so short that they are the first thing which limits down travel, as they ideally shouldn't reach full extension at full suspension droop. Hope that makes sense.
your rear sway looks a little low from the pic angle. On the kits I've installed or help friends install, when they come with sway bar links the new links (longer) go on the rear and the rear stock links go on the front.
you might try removing your rear links and see if what you feel gets better or worse. remember to tie the sway bar up so it doesn't hang loose
Any change in ride height will make your Jeep handle differently when cornering, and mine is no different. I have almost twice as much lift as you, and yes it does go around corners differently.
A couple of questions which should be asked.
Did you have a full wheel alignment after your Jeep was lifted? I would think this would be a necessity after having new control arms and track bars fitted. Wrong alignment/steering geometry will make your vehicle do some strange things when hitting bumps and turning corners.
What tyre pressures are you running? This can also be a massive factor in handling and ride.
As I said earlier, check that your swaybar links aren't reaching full extension (ie. arm on swaybar stretched to be completely in line with swaybar link) before full suspension droop is reached.
Also check to see that the swaybar or its links aren't snagging or catching on other parts of the suspension or chassis. Make sure you check both sides. If it is, there will normally be a shiny wear mark or gouge or scratch.
Hope some of this helps.
Here is a photo of my swaybar and link. When you compare the position of the swaybar arm with the track bar mount, then there isn't much in it between the two.
I think that you shouldn't worry too much about the handling untill after the alignment, but do check those lengths to full extension.
I get regular alignments done, as it only takes a fraction of an inch to make it drive like a dog.
Yes, I think we all get this. It is you who isn't getting us.
But, unless you are driving over an uneven surface or cornering, the only thing your sway bar will do is move up and down with your axle.
Can't imagine why you'd be curious to know what others think being that you already have all the answers.
They're a firm shock and one designed to help absorb bigger hits when driving faster. Paired with a set of firm coils, the two together will offer a ride that is a bit harsh for my taste. But of course, ride comfort and quality is 100% subjective.
Being that you "know things about suspension", I would have thought that you'd know that it all depends on how tall of a lift you install, what kind of coils your riding on, the components you've replaced and how you have them set.
Respectfully, I don't know it all. It is obvious to me however that there is some inaccuracy in some of the responses.
Respectfully, I don't know how it could be so obvious to you that there are what you consider to be "inaccuracies" in some of the responses when you clearly don't know half as much as you think you do.
I am just trying to piece it together. I know some things that can have affect on ride and I am just trying to see what others have experienced.
For someone who claims to know some things that can have an effect on your ride, I find it odd that you'd need to see what others have experienced.
I appreciate all of responses. Sometimes I just think people write things off quickly as they haven't experienced something a particular way or have a certain way they understand something.
And I sometimes think that people like you write things off quickly because you don't hear what you want to hear.
If after I install the longer links it does nothing different for me I will gladly say I was told so. Thank you again.
No need to wait for new longer links, just remove the links you have installed. :naw:
jeramejk said:
Maybe I wasn't clear in the first post. I feel like the rear isn't working in conjunction with the front. Is this just characteristic of lifted jeeps in general?
You're the one who "know things about suspension", why not you tell us.
I understand the geometry changes.
Then I suppose you can tell us how this will effect your ride and handling and why.
It just seems like more than the added height. What differences did you notices going from stock to synergy?
It's funny but to me, stock suspension SUCKS and a good lift should typically offer a BIG improvement over stock. I'd wish you luck in figuring out why your ride sucks even more but then, I know you have all the answers :yup:
Do you have adjustable track bars and control arms?
I have adjustable lowers front and rear and an adjustable front track bar.
I had an alignment done a while back which was perfect, and my Jeep drove great, however after one outing offroad it became a bit skittish again (not as bad as it originally was). I've now had another alignment done recently and it's driving well again. I just hope it lasts a bit longer, and a few more offroad trips this time. I asked the aligner why it would have gone out of alignment so quick, and he didn't really have an answer, only to say it only took mm's to make a difference. He found the toeout to be wrong this last time around.
Any tips or suggestions? I checked to make sure all the adjusters were tight after the last alignment, but is there something else I should be looking at.
It is totally normal for bolts to loosen up after an off roading trip and making sure they are tightened to the appropriate torque spec is necessary part of routine maintenance. Also, off roading can cause things like your tie-rod to bend and that WILL change your toe and that can effect the position of your steering wheel and handling as well.
To be clear, you did mean to say "toe-in" and NOT "toe-out", right? Because, that's what it should be set at - IN by about 1/16" (3 to 4 mm).
One suggestion would be to save your money and stop taking your Jeep to an alignment shop. The following link goes to a write-up I've done that will help you to do your own alignment and for FREE.
http://wayalife.com/showthread.php?3861-Basic-Do-it-Yourself-Jeep-JK-Wrangler-Front-End-Alignment
Thanks for the link, I've already been reading it, and learnt a lot along the way.
Aligning has been one of those things that I've never been confident enough to do myself. I've never had anyone run through it with me, so have just avoided it. I will run through it now guided by your thread instructions, try and work out just what sort of setting my Jeep is at now.
My last 4by (Nissan Patrol) never needed an alignment in the 15 years I owned it, and to need two alignments on my Jeep in relatively quick succession at $85.00 a pop, was beginning to worry me, thinking there is something I'm missing to cause it to go out of alignment.
Thanks again Eddie. I'll buy you a beer one day, or maybe shout you an American Honey.
I never claimed that I knew everything that's just you hearing what you want to. That's pretty hypocritical. I understand suspension as in what each component does and what can cause changes.
Ummm, yeah. You're not claiming to know everything and yet, in the same breath, are saying that you "understand suspension as in what each component does and what can cause changes". Of course, I'm just a hypocrite who just hears what I want to hear.
I just want to know on a jeep how much of certain things matter or are noticeable. Never claimed I was a Jeep suspension wizard that's why I am here with questions.
Funny, I could have sworn you just got done saying that you "understand suspension as in what each component does and what can cause changes." :thinking:
I definitely said that my jeep acts weird on corners and uneven roads yet you say this "But, unless you are driving over an uneven surface or cornering, the only thing your sway bar will do is move up and down with your axle". Are you actually reading my questions or just giving me shit?
You got me there. I definitely missed the part where you said your problem was in "turns and over uneven road". Unfortunately for you, it doesn't change the fact that your sway bar is still just a torsion bar with a set rate. What will make a significant difference in how it feels is in where you mount your links along the arms - closer to the bar, the firmer it will feel. Closer to the end and it will make it feel softer. This is why Currie Anti-Rock arms have multiple settings as it helps the user get a ride they are wanting. But of course, you knew all this already.
Instead I get people saying that sway bars don't do anything to the ride and admin attacks. Thanks but I will be moving on. I thought this would be a respectable place, but instead it's full of sensitive administrators and moderators that think they are the best thing since sliced bread. I used to have respect for WAYALIFE. This has made me feel different.
:cheesy: You're the one who's leaving with his panties in a bunch but we're somehow the ones who are sensitive - got it.
Please don't let the door hit you in the ass as you leave :standing wave:
