I'd call ARB. That's a pretty specific part and I wouldn't think it would be easy to find in the general market.
Would like northridge have it??
did you over tighten it and it cracked? most air fittings are" flared", not sure the correct term, but get wider towards the end of the fitting
I doubt it. They don't deal with parts. As suggested. Give ARB a call. They have the best customer service department.
(866) 293-9078
That's there customer service number. One if them.
Thanks i will call in the am, do you think there is something that i can seal it with just for the week as i am getting a locker put in and im pretty sure they will need it just to run tests??
I'm not sure it can be sealed. Maybe try JB weld. If it's just to test your lockers it might hold for a short while. But don't bet on it. It's a long shot.
I had one that cracked also. ARB sent me a new one after I sent them a pic.
Same happend to me. Call them and the will ship you a new piece. Try not to per tighten, hook every thing up then ru the compressor and tighten till you hear no more leaks. Use lots of Teflon tape
Mine died a couple weeks ago. I had it pulled last week.
Turns out the 'thermal overloads' are bad. Supposedly, this is a common problem with the dual. It's under warranty still, but the part is out of stock at ARB and may take a few weeks. Ugh!
O man that sucks! Did they say if there was a way to prevent that? How did u figure out that was the problem!
When I first installed mine it was bad from the get go. After talking with customer care at ARB, they said they know of the issue. I was told that during manufacturing the issue was not caught. What kept me from being disappointed was their crazy fast service. After the technician explain what was wrong, all he said was there will be a new unit on its way by mid day. Send us your when you get it out of your vehicle. Never has a problem since.
