JK's JK
Banned
But you are looking at lifts when you are looking at coilovers and the EVO Lever. They are what provides the lift for your jeep. The reason EVO mfg says the DTD and EVO lever will work with any lift (well almost any), is that the coilovers provide the lift a conventional spring provides, all you need to do is choose the control arms.
DTD history lesson.....EVO didn't invent the system, they just perfected it for JK's!
The "Double Throw Down", or DTD, simply refers to any suspension that is running a Coilover and a second By-Pass shock at each corner. The term originates from within Baja Racing circles. As Strizzy Chris mentioned, RTguy1 couldn't do the EVO Lever on his rig because he did a stretched wheel base on a two door, which pushed the rear axle further back and doesn't allow room for the frame of the EVO Lever to fit. Depending on your budget, you can run EVO mfg's front coilover (weld-on) kits with only a coilover, or with the DTD option. And again, depending on your budget you can run their EVO Lever rear suspension with a coilover or their DTD option.
This is great information. Still trying to understand all the terms and get the right information to buy the right direction. Trying to get the backend upgraded since with my lift there are issues from what I understand. With the lever system it would seem it would accomplish that issue. But I haven't figured out what a stepping stone to that step, so I don't spend much money on springs/shocks since one of my near goals is getting up to a 4.5-5" lift. As many of these guys run into is the flow of money. Just thinking what I want my rig to be 1,2,3 years down the line to not have to re-org my rig.
I'd have to say since I've been on here you'll been super helpful.
Thank you,
Jesse
