What do people use for a jack?
PD Monkey
What is the go to jack for a JKU with 37's? I don't want to go with a hi lift, too heavy and can be hard to get pickup points. I like scissor jacks because they are light and easy to store. I usually would always keep a few small 4x4 pieces of wood. I have a nice aluminum floor jack that was on my prerunner. I am not sure I want to permantly mount it in the back of the Jeep. AGM makes a nice scissoe jack but it is rated for 2000lbs. Which might not be too bad, if you are only lifting one corner.
I recall that I followed the advice in this video to a T, but found that the recommended jack-buddy (to jack up on the axel shaft) did not fit over the top of the jack (because the mushroom at the top is too large). So I returned it and bought a more expensive jack which is made in the USA.
Well My thought was ....I don't do tons of off road stuff and when I do it's always with other folks....and being I bought my Gladiator used and the Kind Fellow who owned it before to the Factory Jack out of it....I figured it would be better than not having one at all....
The factory Jack may be fine for the street, but not for the trail. The farm Jack is just plain dangerous. The one you bought is likely reasonably safe if on level ground and you use just one extension.
