I took it up above Ramona for a quick flex test and while I couldn’t get fully flexed out, I have a pretty good idea of what else I need to do which isn’t much.
Some slight contact on the corners of the bumper is my biggest issue but nothing critical is making contact so I’m happy for now.
Damn, those things look huge! 😳
Busted down tires today…
I don’t think I’ve ever had beads harder to break than these KMC’s but I’d rather fight getting them apart than have a bead pop on the trail.
Soooo many bolts
I also washed everything and freshened up the beadlock rings. Sanded them with 60 grit on Dewalt 20v followed by some 120 grit on the DA sander. No pictures of that though.
View attachment 435405View attachment 435406
Soooo many bolts
They look good. Love the backhoe de-beader, much easier and faster than a hi-lift. 😂
drove from Texas to Utah towing a 4x8 trailer, cylinder 3 misfire code when making a steep climb in New Mexico when rpm's hit about 4000 🙈 🤬
Used tap shift the rest of the way making sure to keep rpm's below 3500, made all but 1 climb in Colorado with no further issue and was able to maintain speed within 5mph except the climb in Colorado which slowed me to 40 (in a 65) mph to keep rpms at 3000.
I'm debating on where to have it checked, in Utah but I feel prices are higher; or since I'm going back to TX for Xmas, have the mechanic I use there do the repair.
Misfires are always discouraging. Way to stick it out. Glad you made it.
Was it on the JK?
Was it on the JK?
the JLU, luckily I was able to identify the RPM range where it would happen and anything below that it would operate without an issue.
That said, perhaps the tick I've been hearing since new is getting worse and what's causing it to misfire at the higher RPM.
Where did you get those little toe clamps?
lol…. With a set of 5 point harnesses. They’re for bolting the seatbelt to the roll cage
ETA: with the coopers these and a few Irwin rod clamps were mandatory, with the Maxxis I just needed to move these little cleats a few times as I worked around the bead.
I did end up using these on tires 2 and 3 but just to act as an extra hand to get the last 6” of bead started
