This is why I went with the fog lights for the DRLs.I took another look at the DRL and found that I did change the setting yesterday. I didn’t see the change because I had the parking brake on, so thanks to BaddestCross for the heads up on that!
I choose the “Turn Signal DRL” and found that the front signal light is very bright, just like when the signal if flashing.
DRL:
I thought it would be more like the parking light brightness.
Parking light:
I guess it makes sense that you would want the light to be brighter and more visible for safety, but can the bulb handle the additional amps on a continuous basis? I guess time will tell.
This DRL mode also turns on the tail lights. The side marker lights remain off, so maybe having a “parking light” option that would add the side marker lights would be a better approach?
If I have bulb problems, I will ask the developer to look into the parking light possibility.
Same here... and I'm liking it so far.
BTW, my backup camera is on order as well so I'll report back if I have any issues with the PCM part of the install.
Keep us posted. Interested to see how this pans out. Ive been wanting to add a camera for a while nowI got my camera today:
It’s cute, but one problem I see is that I didn’t order a male to male video line adapter. The couple of write ups that read through mentioned that some people didn’t need it, so I didn’t order it. I’m going to have to pick one up if I don’t have something laying around.
Will this tool allow you to change the settings needed for the OEM Mopar LED Headlights?
Congrats.Camera is installed and works great! I’m pretty freaking happy right now! The hardest part was running the wires through the plastic part of the bumper, up over the metal part and into the jack compartment drain. The rest was pretty easy.
Awesome! I am planning to install mine in the spare tire somewhere but this looks extremely clean.
A little bit OT but did you have any issues plugging it into the stock head unit?
I appreciate it but I can grab one if I need it. I need to pull my deck and see what I need. I have an aftermarket deck so not sure if I would need the cable or not. I thought mine just had rca jacks for the camera. good weekend project.Thanks for the links though just in case.Links if you need them:
Rearview Camera Vehicle Backup Camera Waterproof Hidden Mini Camera Vehicle Cameras Back Safety Parking Assist Line, 8 LED Night Vision Lights, Wide-Angle 170 Degrees https://www.amazon.com/dp/B0792M37V5/ref=cm_sw_r_cp_api_i_1KAICb8T2E8SN
PAC CHYRVD Rear Video Retention Cable For Select Chrysler/Dodge/Jeep Vehicles 2008-2012 https://www.amazon.com/dp/B0051XBNDY/ref=cm_sw_r_cp_api_i_dMAICbBA5G2MR
Don’t forget that you need one coupler:
Cmple - RGB RCA Coupler Video Audio 1-RCA Component https://www.amazon.com/dp/B003Z9WPQU/ref=cm_sw_r_cp_api_i_XNAICbCPRVKBP
I have a spare one. PM me if you want it.
Sent from my SM-G965U using WAYALIFE mobile app
Camera will be here Sat. See what I need after that. With a lil luck l, maybe just a run to Best Buy or something for an extension. Will let you know.That would be cool if your head unit does just have RCA jacks. Cheaper too!
The one you sent the link for. Just trying to decide where to put it. Thinking welding a tab to the license plate mountWhich camera did you go with?
