Been looking at inner fenders and I was wondering if the aluminum inner fenders are more of a cosmetic thing or do they provide a real gain in cooling?
Heat rises, so I would say it's negligible. You'd be better off getting hood vents.
I have hood vents, I'm just curious more than anything, I guess it's just more of a cosmetic thing.
not just a cosmetic thing, it helps to protect whats behind it such as all the electronics. the stock ones are pretty pliable plastic, aftermarket steel or aluminum are a huge upgrade in protection. think of it like a diff cover. the stock one does the job but the aftermarket adds protection to the critical parts inside
Have you ran without ANY liner and had a problem directly related to NOT running a fender liner?As with all things it's subjective. In my area I'm throwing up small rocks, mud, water, branches etc. Since I've already ripped one I know it helps protect where I'm at. You may not need/want them and that's your choice for your rig
Sent from my SAMSUNG-SM-J327AZ using WAYALIFE mobile app
I guess my point is just because you WANT them to protect your rig, doesn't mean they ARE protecting your rig... Just saying...
sent from SPACE!
DZZ Build thread
I've been to hiddenfalls over a dozen times... yet I've never had that problem. Sounds to me like this guy would have seen the same failure regardless of a fender liner or not.I saw a guy at Hidden Falls destroy his engine the first day of the weekend, before he even made it out to the trails. There is a decent sized puddle towards the back of the park. He had removed his fender liners, and was running an open air filter. Bonehead move. The water was only around 2 feet at the time. The splash, lack of fender liners, and open air filter all contributed to him sucking up water and destroying his engine. If you do that kind of off-roading, you should probably expect mud/water to find its way into a spot where it could cause damage. They were installed for a reason...best to keep something there.
They do LOOK badass! :thumb:I think they look bad ass and clean up the front nicely, just get them if you have the cash!
Picture:
Picture:
I think the double throwdown is handling most of the typical liner duties. :cheesy:
