I'm going to be redoing the lift after I get a winch, regear, ball joints, and c gussets done. This time around I'll be doing: evo plush ride springs, 5160s or ipf's, evo rock star's, extended brake lines, evo drag link flip, a front drive shaft. Then get a full set of arms and track bars to be ready for 37's
Here are some things I've had issues with concerning my tf 2.5 coil lift and the reason why I'm gonna start over: no front brake line brackets lead the scary tight lines at full flex and turn, I really thought I was gonna snap a line. I since added brackets, but as I'll get to later, I don't think they are enough. I don't get full droop on the drivers side due to driveshaft contacting cross member, this lead to the boot getting ripped off and the drive shaft has a groove being worn into it and the cross member. Sure I could solve that with a new shaft, but what ever. Front spring sag is really bad. I don't even have a winch yet and only a stubby bumper, yet even with a 1" spacer up front I have front rake. Its annoying. The shocks suck, maybe not as bad as stock non rubi shocks, but they are def a worse ride than my rubi shocks where. The rear brake line drop brackets are not enough. I now have a mangled driver side hard line due to the rear line being stretched enough to pull the bracket enough, which allowed my hard line to bow out just enough that my tire grabbed it at full stuff... So enough is enough
I'll take a picture of it if anyone is curious. So all this and I'm done with this lift, thank god I got a good deal on it second hand from a friend that moved to coilovers. If I had spent $800+ on this I would cry
