JT Rear Axle Seal Leaks
kevman65
Read about this elsewhere, sharing here.
Passenger rear axle seals leaking. Build dates from Sep 2020 forward. It appears the problem only shows up on the wider axles.
Fix is replacing the rear right axle shaft as the shaft, bearing, seal come as an assembly. Currently the back order on the rear right axle shaft has stretched to December of 2021.
Speculation is either a bad batch of seals, or something wrong with axle assembly.
