mgmavant
Hey folks, I have been having electrcal issues with my Jeep for a few months now, and I'm looking for some advice on what my next steps should be. My 08 JKU with 170k miles started having a no-start no electric power isse where I would go to start the Jeep and I would get a click and then loose all power to the Jeep (no dask lights, no dome light, no radio - nothing). I first checked and cleaned the leads on my battery, and that seemed to clear the issue for a little while. A couple months later, same issue that was resolved by cleaning and resetting battery leads and terminals - even though they were all tight and in great shape. Another month goes by, and same issue with single click, loose all electric power and can't start the jeep. This time, no matter what I do, I can't start the jeep, so I put a new starter on.
This seems to solve the problem for a short period of time (week or two), so when I have the issue again, I decide to check the starter to make sure it didn't crap out on me - starter was fine - so I decided to change out the battery and alternator (they were both working, but not very well and I knew I needed to replace them sooner rather than later).
Changed both of those out and added an additinal ground wire to make sure everything was grounded well (new wire from neg battery terminal to alternator mounting bracket). The Jeep ran great, until the same issue happened yesterday. Checked all the leads and terminals and everything looks great. Great voltage on the battery as well.
So current issue right now is that when I go to start the Jeep, I get a click in the TIPM box, and as soon as I try to start the Jeep, I loose all power to the Jeep. Easy to reset by just removing the positive terminal on battery and putting it back on and power is restored to the jeep. That seems to reset something. Power is good until I go to run the starter - thats when I get a click and then no power. If I reset the powr again, I can jump the jeep manually and it will run just fine (it's a 6spd manual).
Any thoughts on what i should do next?
Thanks for the help!
Spike
Spike
