Dana 30 rebuild questions?
Fragman565
Hi my carrier is going bad 3.55 gearing buying good used carrier need to know if I should buy shims or master rebuild kit or can I resuse the old shims and bearing but diff is slipping worse now that I put new fluid in it
93grandzj
As long as its the same gear radio you can use the factory shims. And buy the rebuild kit so you can put new bearings on the carrier.
And welcome to the form
Sent from my HTC VLE_U using WAYALIFE mobile app
