2021 JLUR suspension into 2019 JL 2dr.
JR-G
I have the shocks, control arms, track bars & springs from my 2021 4dr Rubicon.
Having trouble finding info on someone putting this suspension into 2019 JL 2dr.
( I have friend with the 2dr)
What will the benefits be?
Is the swap straight forward?
Thanks
CalSgt
Little bit of height & Rubicon shock valving. Ride will probably be stiffer too
Swap would be simple, loosen all control arm bolts, remove shocks, jack up & put jack stands under the frame, let the axle down until you can pull the springs out, put in new springs (check part numbers to see which corner they go on) and jack up axle until new shocks can be bolted in, set it on its own weight & tighten control arms to spec then repeat the process for the opposite end. Check and set your toe on the front tires.
I can do it by myself in about 2.5 hours (or less) with moderate skill level & a decent set of tools.
Heres a video on a different lift install that is a little more involved but will give you an idea what to expect
https://wayalife.com/threads/video-jl-journal-dynatrac-endurosport-2-lift-kit-installation.54984/
Link to alignment write up
https://wayalife.com/threads/write-up-basic-diy-jeep-jl-wrangler-front-end-alignment.56571/
ETA: Heres a link to the torque specs
https://www.wayalife.com/threads/torque-specs-jl-wrangler-reference-guide.52799/
JR-G
This is great, thanks.
